very happy with my PUIG CF-look hugger...plus a whole cheaper ]
I have puig one on shelf ready to go..
I have the Pyramid and it really keeps the road grime off the rectifier due to the extended length.
maybe i had a dud or installed it improperly but my pyramid alot! i tried to reposition the bolt holes and finally ended up cutting the neck portion that covers the rectifier. it would constantly rub the tire and rattle against the recitfier. now, it works fine without the neck so all is good but i would of preferred not cutting it. ???
i bought it from the same people and the service is great but my hugger isn't. i should have bought the puig instead because i like the chunky look better and the fit is very good. hopefully, you'll have better luck with yours and i am curious to see if your hugger rubs or bangs off the rectifier.That's one reason I'd consider going the Pyramid, shame you had to cut it...
Did you buy yours locally or did you have to order on-line?
... and from who?
Where or who did you get it from?
Sorry brother, been a bit busy as of late.
It was purchased from streetfighters by design
Streetfighters By Design
$180 total shipped to Fla.
