Turbo-single-sided project
magifesq
2005 with mismatched plastics and single sided swingarm.  I'll be posting these in the classifieds later - need a rear seat if anyone has one, possibly a grab bar and solo cowl too.
Torn seat ok, I just need to have a pad and foam to cover.
Pic #1
why the innercooler on the side of the bike? they make em to fit under the plastics...
(magifesq @ Apr. 01 2007,00:45) Where and how much?
dennis has em... for like a grand I think
hayabusaparts.com images missing
Get an intercooler made for a Busa turbo kit and you could install the plastics again.
Swingarm came off of a 91 VFR 750 I bought for a different project.
Velocity stage 1 turbo kit I bought from GM Busa? I believe.
Dyno Tuned this weekend and making 232 HP & 138 Ft-lbs torque.
Pic of the intake
Here's a pic of the backside. The original backside plate looked a bit too restrictive around the wastegate, so I cut out a bigger hole and welded more pipe onto it.
Thanks bro - I should have boosted some of my previous busas. Man its fun!! I cranked the shock down and kicked the back end up a few inches, now it puts the power to the ground without the struggle to keep the front end down. Shifting the center of gravity really helps me use the boost without being the danger of flipping it.
