Turbo oil pressure regulator
Deez ballz
Hi,
Does anyone use a oil pressure regulator for the turbo or is it not necessary.
gen 2
thanks
Quiksilver
Not that I'm aware of but I know some run a restrictor in the. All bearing turbos. What turbo do you have?
Quiksilver
Sorry no definite answer but I would assume you wouldn't need one. I've heard mixed result but maybe check what the manufacturer recommends.
bshay20
If your drain is sufficient then no restrictor for a journal bearing turbo. I have seen some JB PTE turbos need one but typically not.
