This is a fantastic idea! It will be a great way to have a TRE when you need it and have a proper gear indicator the rest of the time.Anyone know? I'm planning to set the shift light to this rpm and let it drive a switch that connects the 22 kohm no-speed-limiter-resistor at this rpm.
Thanks a lot !In reality, it doesn't much matter what RPM corresponds to 180mph, since the limiter isn't based on vehicle speed anyway and won't change based on gearing. All you need to do is set your shift light for 10,200 RPM, which is the limiter in 6th gear.
Great idea, BTW.
