Transmission questions
If you know how to use tool's and have common sense it can be done.You purchaced a busa so you have common sense. I've been a mechanic for awhile but found it simple to do with a haynes manual. You CAN do it without thking the head off. Just watch out for sensor's and thing's to break when the engine is upsidedown on the bench.All you have to look out for inside the engine is the lower cam chain guide. Make sure it slip's into it's pocket when putting the lower case back on. Where you from? Post up and someone might give you a hand. Then you can help them paint there house or wash there car once a week for the summer for there help:laugh: Good luck.
I noticed this bike is much easier to miss a gear on than my gsxr 1100, 750, or even my dirtbike. It's a longer throw. Doesn't equate to a problem necessarily (with the bike anyway)
