actually I have a microwave perimeter sensor on the bike -- so I know no one is Jacking meI thought everyone knew that they do things a bit backwards in LA.
j/k - That is strange though. The screw should want to vibrate out, not in. Has one of your buddies has recently purchased a long skinny screwdriver recently?
I have a devious mind
temperatures here are similar -- but humidity is a lot higher here most of the time -- wonder how big a factor that is ?I've noticed in cooler air temps it'll run a higher idle and in hot air temps it'll run lower.
So colder air is more dense than hot air, which means more oxygen in cold air. So when its hot, my bike is too rich and idles low. While in the cold, the mix is just right and it idles higher.
A guess anyway...
