Howdy!
Ok…I’ve done some research on cush drives and axels, and am still not sure what might be the issue.
While parking the bike at home I noticed a small noise when pushing the bike backwards. It does not make the noise while rolling it forward. It was coming from the rear wheel. It makes the slight squeak in a rotational manner or about every half foot I roll it. I put it up on the stands and it doesn’t make the noise at all. I recently changed out the rear brake pads/cables and thought maybe it was that….but not the case. In fact everything sounds quite normal. I did notice that the sprocket drum appeared to have an ever so slight movement separate from the wheel itself. (ie I can turn the wheel/tire and for a very miniscule fraction of the movement (hardly any in fact) the sprocket drum doesn’t move, until it catches shortly afterwards – is that normal?) I cleaned and lubed the chain and put her back down….. and the squeak remains.
Help?
Thanks so much!
Help?
Thanks so much!
