Could you explain how you do it the right way ?? been shifting like this forever...(dirt bike roots) never hurt one yet.. (knock on wood) Only issue I have found on the Busa is a lack of commitment... if you get lazy, there is a false neutral between 5 and 6
I have always used my clutch for fear of damaging the tranny, but have often considered trying it.. I appreciate the advice and warning.. Thanks !!As posted above, if you have problems with this you could likely do damage so be warned... I just assumed most people did this is all.. do not want to get you into trouble ok?
+1 on 1st to 2nd and I would like to add 5th to 6th. I always clutch it. Why? Because the knowledge of the Busa guru's have spoken and I am a good student.I ALWAYS use the clutch going from 1'st to 2'nd !!! That's where you can get into trouble. In a magazine I read that motorcycle transmissions are not the same as a cars, they only need an interuption in the power, not a pause like a car, and to LEARN, just pre-load the shifter, then blip the throttle (don't chop it all the way off) it's almost just a little more than a thought, and as it shifts get right back on the throttle. I don't like the idea of pre-loading the shifter. But as long as you're not riding for any length of time doing that you should be okay.
I'm not suggesting anyone do this, I'm just saying that's what I do !!
But when doing this I never hit false nuetrals, or catch that 5'th-6'th gear snag. It's just SOOOO SMOOTH !! They say you can do this down shifting as well, but I NEVER have.
I posted in a thread that a dealership was saying that this is what was causing the bent shift forks,
Same method I use except I also do it from 1st to 2nd. I did manage to bend a shift fork by doing this and thought I blew out 2nd gear. This lead me to get my tranny undercut. The good thing is it was only the fork and not the gear that went bad. The better thing is that now that I have all my gear undercut I can do it without a care in the world.+1 on 1st to 2nd and I would like to add 5th to 6th. I always clutch it. Why? Because the knowledge of the Busa guru's have spoken and I am a good student.I ALWAYS use the clutch going from 1'st to 2'nd !!! That's where you can get into trouble. In a magazine I read that motorcycle transmissions are not the same as a cars, they only need an interuption in the power, not a pause like a car, and to LEARN, just pre-load the shifter, then blip the throttle (don't chop it all the way off) it's almost just a little more than a thought, and as it shifts get right back on the throttle. I don't like the idea of pre-loading the shifter. But as long as you're not riding for any length of time doing that you should be okay.
I agree here at least while you are perfecting your technique.+1 on 1st to 2nd and I would like to add 5th to 6th. I always clutch it. Why? Because the knowledge of the Busa guru's have spoken and I am a good student.I ALWAYS use the clutch going from 1'st to 2'nd !!! That's where you can get into trouble. In a magazine I read that motorcycle transmissions are not the same as a cars, they only need an interuption in the power, not a pause like a car, and to LEARN, just pre-load the shifter, then blip the throttle (don't chop it all the way off) it's almost just a little more than a thought, and as it shifts get right back on the throttle. I don't like the idea of pre-loading the shifter. But as long as you're not riding for any length of time doing that you should be okay.
Good add on downshifting. proper method for downshifting clutchless is to not do it at all. With that said, I have downshifted clutchless with a steady 1/4 open throttle in an emergency stop a time or two. Would not recommend it though.Same method I use except I also do it from 1st to 2nd. I did manage to bend a shift fork by doing this and thought I blew out 2nd gear. This lead me to get my tranny undercut. The good thing is it was only the fork and not the gear that went bad. The better thing is that now that I have all my gear undercut I can do it without a care in the world.+1 on 1st to 2nd and I would like to add 5th to 6th. I always clutch it. Why? Because the knowledge of the Busa guru's have spoken and I am a good student.I ALWAYS use the clutch going from 1'st to 2'nd !!! That's where you can get into trouble. In a magazine I read that motorcycle transmissions are not the same as a cars, they only need an interuption in the power, not a pause like a car, and to LEARN, just pre-load the shifter, then blip the throttle (don't chop it all the way off) it's almost just a little more than a thought, and as it shifts get right back on the throttle. I don't like the idea of pre-loading the shifter. But as long as you're not riding for any length of time doing that you should be okay.
It should also be mentioned that DOWNSHIFTING cluthcless is much more risky than upshifting. I had my tranny racecut but am still too timid to try clutchless downshifting. I don't know the proper method so I don't bother.
