jch364
- Joined
- Mar 19, 2006
- Messages
- 2,630
- Reaction score
- 827
This is an exact mirror of my situation. I did a post on it. My second gear and first were slipping. I had both replaced with new bearing and while i was at it my shop replaced both upper and lower along with new oil pump, and pick up. then they did the top end by degreeing the cams and putting an intake on the exhaust side and then milling the head. also cleaning the valves and putting in new seats for the valves. everything is new now except the pistons but they were in fine shape. you could still see the honing marks on the piston walls. I had 42k miles on it when i did this. I drag race it alot too. If you have someone who knows what they are doing. i mean really know. and have them degree the cams and put the intake cam on the exhaust side and mill the head to the right spot then it will give you the power you want and keep it at 1300cc. assuming you have a good tune. I have a brock alien head with a brock map on my 06 so i didnt need a tune. gas is still 87 pump. pulls really hard now all through the band. hope this helps. good luck with it
