Depending on the state of tune of your engine, it may be beneficial or not. Octane
SLOWS combustion. 100 Octane in a stock Busa engine is overkill and can slow combustion to a point of slight-but-measurable power loss. Each engine requires "X" amount of Octane for proper operation. ANY MORE Octane than
that amount further slows combustion and lightens the wallet unnecessarily but I am not aware of any other negative long-term effects from using higher-than-needed Octane. Suzuki tells us that 87 Octane is the "X" amount required for the Busa and dyno tests have supported their claim. In your case with nitrous, the higher Octane gives an added measure of protection against preignition and/or detonation. Preignition (pinging) is relatively harmless but detonation will quickly kill an engine. So, if your engine is stock and in good condition, 87 will work fine but 100 is extra insurance during those impromptu nitrous blasts. There are some other variables involved in Octane requirements (even for stock engines) such as carbon deposits in the combustion chamber, ignition timing, ambient temperature, etc., that could require higher than 87 to prevent preignition and/or detonation. I would say that you are okay as long as you can afford 100 but it is does
NOTHING for a stock engine in good condition.
