busa_soldier Registered Apr 16, 2010 #1 just installed galfer rear rotor along with pads and lines my problem is the rotor is rubbing the caliper mount bracket any ideas :confused2:
Acehole The crowbar! Donating Member Registered Apr 16, 2010 #3 aussiekeeper said: Flip it over......... Click to expand... If it's a genI, I say the same. Dont know if GenII has the same off set spacer/bracket.
busa_soldier Registered Apr 26, 2010 #4 thanks for the replies guys tracked it down to a missing rear axle spacer. part ordered,replaced problem solved :yes:
D DarkScorpion Registered Apr 27, 2010 #5 Wow got the same problem what type of spacer did you order and from where???
busa_soldier Registered May 3, 2010 #6 it was the rear right hand spacer on the rotor side ordered it from cheapcycleparts.com
D DarkScorpion Registered May 5, 2010 #7 Thanks for the info Bro I will check and see if that helps me!
