Robertboulter
Went for a ride out to Matlock Bath in September last year and she died on the A50 with a strong smell of sulphur. The battery had started to melt so I disconnected it. got home and found the reg/rec to generator plug had failed blowing all the bulbs ,melting the battery and killing the ECU. All the bulbs and fuses have been replaced, the reg/rectifier tested (was ok) and a new plug fitted. managed to acquire a good used ECU but bike still won't start. I'm getting a flashing red F1 light ,the code is c42 which I believe is ignition switch signal. Does the ECU need to be married to the bike as with cars or is there another problem.
Bob
Bob
