shade
So my plan is to replace the stock lines with SS from coremoto and Brembo RCS clutch and master.
I'm going to leave ABS alone (I hear @c10 snickering now)
My thought is to use the mityvac and pull the fluid from caliper 1 then caliper 2.
Then the rear
Install the lines
Fluid in the master and use the mightyvac at the caliper to start pulling fluid until I see it coming out.
Move to caliper 2 and repeat.
Same for rear.
I can then use the bleeder on the clutch and master for final bleeding. Then if needed crack the line at the ABS module for bleeding.
Missing anything?
Then the rear
Install the lines
Same for rear.
Missing anything?
