V-Max 2 Busa
Replacing the factory rear fender required I remove the reservoir hose between the master cylinder and the reservoir thus removing the brake fluid to that level, refilled the reservoir after reassembly, brake stops the wheel fine when the bike is on the stand but dosen't feel very strong while riding. Would droping the fluid level to that point allow air into the line? Do I need to bleed the line?
