There are two small allen wrech screw on each side remove the screws. Take your fingers and pinch two ends of the rubber boot together. Use a pair of needle nose pliers and grab the pinched area. Rotate around in a circular fashion while pulling them out.
Once out remove windscreen and put new one back in. Make sure you have the hole lined up with the windcreen hole. Take your thumb and push the rubber grommet in very firmly and it should go right back thru new windreen and nose plastic. If not. Use the needle nose pliers and place in middle of grommet and apply firm , but even pressure. It should go back in, Then screw in allen bolts and whalla!! your done. You don't even need to remove inner fairing around the cluster. to do. Should take you five minutes with the right tools.
ok, what i dont understand is what does the little allan screw screw into???
i have no nuts anywhere.. I took everythin off an d stuck it right in a bag...
Im so frustrated.. Not to mention this sportech windscreen fits like poop...
VERY frustrating.
Ok, now the allan screws are they big??? I hate to ask this but does ANYONE have a pic?? or can get a pic of something...all this work and i cant get one fuckin windscreen on.. iM SO PISSED...
You said something about a grommet??? IS the grommet on the windscreen? or is the grommet on the fairing??
Im looking at the diagram and i dont see anyting to have to do with a rubber grommet....
