my 01 turbo bike has the ecu upgrade and has run fine for a few years now with a used pc3usb in it. Then the bike decided not to start and I traced it to what I thought was the pc3 not supplying enough voltage to the injectors; the bike starts and runs without the power commander plugged in, but won't start with it plugged in. It will initially fire for a split second but then won't keep running. I also have the ecu flasher wired in and it has worked fine and I can flash. I tried a different ecu with the same results.
So I got on the phone with Dynojet Tech help and after their phone help I exchanged the pc3 for a new pc5. Same problem. With a zero map or my old map it has the same problem, so my dyno guy told me to send the pc5 back and have it checked because with a zero map the pc5 should have no affect on the bike, which I did and it passed all their tests and they returned it. Bike wont start with the pc5 connected. The battery is reading 10.9 volts across the battery terminals when cranking. With another battery jumpered onto mine it reads 11.7v and still won't start. Dynojet tech help says the only thing their pc5 does is intercept the injector signal and only reads from the TPS and their only suggestion is not enough voltage during cranking, which appears to not be the issue. My TPS appears to be working fine. I can set and reset the TPS values in the pc5 when the fuel pump is on during cranking. If it was the TPS then I think the issue should also show up without the pc5 plugged in, but it doesn't.
So I have been riding around without the pc5 plugged in because I can't resolve the problem. The bike starts fine and is rideable, but the map is way off. I have 40 lb injectors but they were not an issue for 3 years before all this hassle started.
Any pc5 gurus out their with any thoughts on this?
