Rivercop UK
- Joined
- Jun 19, 2016
- Messages
- 148
- Reaction score
- 125
Hiya,
Noticed that my bike is idling a little rough after the PCV / Autotune install. On idle, the bikes reporting its AFR to be in the low to high 15's.
I checked out a video to sort this, but the guy was using one fuel map for all the gears ... So he just set up autotune to run AFR 13.8 at zero throttle / 1000 & 1500 rpm which sorted the naff idle.
However, I'm running individual maps for each gear, so I don't have a 'Neutral' map so to speak. I guess adding autotune info to the same area's won't work on mine, as it will need to be in gear to access those cells.
So, is there a way to add autotune to 1000 / 1500 rpm in neutral or would I need to access the ECU and add fuel there using the boostbox ?
Cheers.
Cheers.
