Do you always use 1/2" stuff???I have no experience with oring blocks at all.I was told to use it with a regular head gasket. Not sure if I should use it or not.I like the promod studs myself, but always leave it as an option for extra assurance.
Orings I like to use them, specially on bigger bore high boost stuff.
How much have you pushed the 10mm stud and oring setup to??? Less than 500 rwhp???Pro mods are the 10mm studs. And I've only build a hand full of engines with the 1/2" stuff.
Regular head gasket is fine. The oring is simply a way to clamp the head gasket down more.
It came with a project bike I picked up. I'm interested to see if the 10mm promod studs and this oring block would hold 25-30 psi.If you pulled it apart and it had regular gasket then i would replace with same
