Oil pressure /Oil Temperature
madlyhs
Anyone knows what is an acceptable oil pressure/oil temperature for the Busa 02 ?
Also can I do away with the oil cooler or is that a must ? I need more space in that area
Thanks
Mikey D
Don't know what the tmp i supposed to be but I can tell yo Not to do away with the cooler.
(Unless you don't plan on riding her that is)
Mikey D
OK, looked up the specs:
Above 200kPa (28psi)
Below 500 kPa (71 psi)
@ 3000 RPM, oil temp at 60 C or 140 F.
I believe the oil temp is for checking purposes, and not a maximum temp.
Hope it helps.
madlyhs
Thank you for the feedback , I guess will have to do more research regarding the oil cooler.
Rosco
What ever you are planning to do to your bike, I wouldnt remove the oil cooler.
You would really be suprised how much cooling duty oil performes in an engine!
If anything, when we mod our bikes for a substantial HP increase its worth while thinking about upgrading water/oil cooling systems.
More HP usually means more heat.
Cheers
Ross
<!--EDIT|Rosco
Reason for Edit: None given...|1089603972 -->
madlyhs
Thank you , point taken . You are right everyone I asked said the same thing .
