nitrous help
wildwilly44
i have the dyno tune twin bottle dry set up 16/40 yosh rs3 slip ons pcIII usb 30 horse jet
i went in and doubled the map at all rpm ranges for wot does this sound bad good or does anyone have any ideas? I will drag race the bike tomorrow at sea level
hopefully i have included enough info
Primary injectors on the GenII are small so the changes you make on your PCIII are much bigger if you are only controlling the primaries. You would need to add about +35 as a starting point for a 30 shot.
GenII or GenI? Big difference in answer.
VERY TRUE! On my 08 i had to take the 100% column(from abot 7500rpm's up)to about 90% to "START" to get the engine fat enough for the spray! Think i ended up at 95-100%? I'm gonna end up going to bazazz :banghead: Sucks cause the PC3 only controls (1) set of injectors!!!
I run my PCIII on the secondary injectors since the motor only sees 100% throttle anyway. Save your money until the GENII ECU is hacked. Then it will be trivial to change rev limit and multiple maps.
