For those neon types. LED BARS. 10 MM long. Various colors. 12Volts. $20.00
Everything as in neon but LED.
6" stips as well, not tubes but stips.
$15.00 for pair.
Description: High Brightness - SideWinder produces brightness values consistent with neon (even in white!) and is up to 3x brighter than other competitive technologies. Side-Illumination - uses high brightness side-illuminated LED modules Even Illumination - even in Channel Letters as shallow as 2.5†Easy to Install - VHB tape to peel and stick directly to the side of the can or VHB mounting clips to attach to the back of the can SideWinder side-illumination system floods the can evenly, making part placement less critical than back-lit LED systems. Sold per foot (2 modules per ft.) Max 50 ft. per roll. Quantity Discounts Available, call for details.
Compaired to Neo LED pods at $49.00 each.
JD
<!--EDIT|ICEMANN
Reason for Edit: None given...|1137036087 -->
$15.00 for pair.
JD
<!--EDIT|ICEMANN
