need map for hahn kit
MET
The Watcher
I highly suggest that you have a map made to your bike, or pop goes the weasel.  Even if you are looking for a base line map find someone that can put in -negative timing and make all the fuel adjustments starting off with race gas and then tuned with pump.
<!--EDIT|Ninja Eater
Reason for Edit: None given...|1100827208 -->
