Aly Kabil
Hello everyone
i decided to open my engine to learn how everything is working inside after i rebuild the engine i took the bike for a few rides and everything was fine and one time i was driving on 280km/h on the 5th gear and wanted to shift for the 6th with the quick-shifter the dashboard shows 6th gear but the engine start cutting out like it is on neutral i downshift again for the 5th it was no problem when i shift back to 6th it do the same then i downshift again to stop the bike and its stuck on the 3rd, 4th, and 5th i cant shift for 2nd or 1st or neutral, i went back to garage and i put the bike on the rear stand and tried to move the tire by my hand to get it to neutral and the gear indicator is getting crazy jumping from 5th to 2nd to 5th to 4th and when i turn the tyre back its stop coz of the gear but if i push it in the driving direction strongly it start to move hardly then easy, i open the engine and i found the 3rd 4th and 6th gear locking pins are worn and the 2nd driven sprocket not in good looking and it have strong play coz of the ring drive shaft friction is destroyed and i found some of it already in the oil pan like rubber parts... can you please help and tell me what is the reason of all these damages or what i did wrong when i rebuild my engine or its something normal for all the busas as i read a lot of forums that it can happen
thanks in advance for help and here are some photos and link for video
