Gary Thompson
2005 Suzuki Hayabusa all stock except for a full voodoo exhaust no cats or baffle. The problem im having is it idles with a miss and boggs down under acceleration in any gear, randomly backfires through exhaust only at idle. I have replaced and checked the following items. Any help would be greatly appreciated. Thank you
Spark plugs
Fuel injectors
Stator and crank sensor
Rectifier
Cam sensor
Fuel pump and filter
Set the tps sensor
Check ohms on all 4 coils
Spark plugs
Fuel injectors
Rectifier
Cam sensor
Set the tps sensor
