2005 Hayabusa throttle issue.
Gary Thompson
Hayabusa bike starts and idles great now will rev fine if done slowly if you bill the throttle it will cut out also if you twist the throttle slowly and try to hold it at say 3000 rpm it misses out and stumbles. Things I have done so far listed below. Thank you all for any help.
Verified timing and valve clearance
Installed new fuel pump and regulator with filter.
New fuel injectors and fuel line.
New spark plugs and ohm checked the coils.
Synchronized the throttle body’s.
Set the TPS sensor.
Checked compression 142 on all four cylinders.
Replaced all vacuum lines with new ones.
New rectifier and crank sensor.
New voltage regulator.
New cam sensor.
Report
Hayabusa Wannabe
Gary you may want to abandon this thread and continue at the other thread below that you began. There was already some replies. Starting over will be confusing to members.
Did you double check your method, particularly the equipment for compression testing?
