Merry Christmas!
I'm wiring in a relay for an HID set up. I would like to power the ballast when the engine is running instead of from the headlight wire which is always hot (mine's a Y2K) I thought there was a post on how to do this, but I'll be damned if i can find it. It looks like I should be able to tap into the red wire from the rectifier, or at least one from a plug "downstream" from the rectifier/voltage regulator. I just would rather check before cooking components
