Need Advice -FI Light Keeps Coming On
Goes9s
I was hoping someone may know the cause for my FI light issue. I just finished my 1397 upgrade and when everything was put back together and we tested it on the dyno the FI light kept coming on when we hit the rev limiter. Didn't seem to hurt the power on the dyno run. Also when I road tested it the FI came on with just high RPMs. And another issue, the FI light comes on when I use the MSD Launch Master (2 step) for more that 3 seconds. Any help you can provide is greatly appreciated.
Professor
Hayabusa Immortal
To much injector dwell/duty cycle, maybe? Are you using a PCIII? What are your highest + numbers in the upper RPMs?
My launch master set my FI light. I don't remember how much time to takes, but it would set it every time.
sixpack577
Top Gun
Would having the bike in dealer mode help? Maybe it would flash a code when the fi light is on, and help you narrow it down.
Goes9s
Yes, I'm using a PCIII. I'm still using the stock rev limiter so on the dyno when we hit 11,200 the FI light comes on. One time the code sent was for inject 4 but we didn't see anything wrong with the wiring or connection. On the street it comes on when i get close to 10 -10.5k at hard acceleration. If I creep it up there, np.
So your FI light comes on too with the MSD Launch Master? Did you ever figure out what the issue was?
Professor
Hayabusa Immortal
Didn't see a way around it.. I was killing the fuel for shifting so I'd set the FI light on the run anyhow. It thinks a coil is going bad. All 4 of them.
Professor
Hayabusa Immortal
Swap number 4 injector with 3 and see if the code moves.
Latest Bikes
Forum statistics
Threads
173,370
Members
47,928
Latest member
Jocor
