busa1300nut
Ok guy.s, here,s my problem. I have an 02 with 57000 on the clock, slip on,s, no pc. At wot, she,s missing like it,s starving for gas, but if I back off the thtottle, just a little, it clears up. I checked for codes, onle got the coo code, no fault, but I noticed my tps was at the bottom, not the center, Well, when I raised the tank and messed around with the tps, I noticed it jumped back to the center where it belongs, but the set screw was not loose, but if I barely tried to move the tps, it will jump from center to bottom, and move it a lil more, it goes back to center.. Is the tps that touchy? Well, anyhoo, I think it is a fuel flow problem, I tried the injector cleeaner, not much differance. A friend of mine is coming over fri, and were switching tanks to see if it might be my pump bad or cloged.
Just wondering if anyone has any other ideas in case the tank swap doesn,t work.
Thanks in advance!
Thanks in advance!
