jch364
ok so some time ago i had an Alzheimer's moment or maybe it was dyslexia and i tightened my oil drain bolt instead of loosening it to drain the oil. Above pun intended.... or maybe not? Anyway when i got it fixed the drain plug was re-drilled and a different drain plug was put in and it does not have a magnetic end to it. I tried taking it to a couple of different places to see what it came off of and to get it replaced with one that is magnetic but i had no luck. So i bought one of those earth magnets. Its a cylinder style and only about an inch in diameter and i need to glue it to the bottom of the drain pan behind the drain plug to catch the crud the filter misses.
The problem i have is i simply cant find anything that will work. I tried JB weld high temp and its crap. the vibration just broke it loose. Thankfully the freaking magnet has such a pull on it that it just slipped back a little and grabbed some metal and was still there after the ride. I cant find any glue stuff that seems to be able to handle high temps. Im not sure exactly what i need but im getting frustrated. I would think there would be some good cement i could use that would handle the heat and vibration without a problem. maybe im just looking in the wrong places. I dont want to loose the magnet cause it cost me like $30 cause i got it with a little over 100lbs of power.. powerful little sucker ill tell you that. anyway any ideas would be appreceated.
