Help please!
I have a 2014 busa and she has 12,000 miles she's been very well taken care of but theres this horrible vibration she's making all over the bike in every gear and when I'm accelerating from a stop in first it's got this weird noise it's making but this vibration is getting worse and worse. I can feel pretty soon something horrible is going to happen.
Now when the shop changed my tires last I noticed that they had knocked my wheel weights off my front wheel and my back wheel wasn't set either they had to get both wheels rebalanced and after that she rode good again for about 100 miles but right after 100 it started in with this horrible vibration feeling throughout the whole bike. I need help asap. Please!
WuzzaCBXRider
Put it up on stands and rotate the wheels and try rocking them back and forth to check for overall tightness of the wheel bearings and axle nuts front and rear. See if all your brake pads are still there. Check the drivechain alignment too. Doesn’t sound like your shop gave much of a shiite about their work so I’d recheck everything they touched.
I can highly agree with you on that. And this is my baby. I can rebuild a Detroit 60 series engine in 12 hours. All my other bikes I have no problem fixing but this bike I have taken her in regularly for maintenance and it's as if theres some job security going on and if that's the case I'm going to lose my mind
Kiwi Rider
I wonder if they left the spacer between the sprocket carrier bearing and the wheel bearing out.
When the wheel is removed and the sprocket carrier removed from the cush drive rubbers, it happens occasionally where the spacer drops out unnoticed by the mechanic.
If it's reassembled WITHOUT this spacer, and the wheel refitted to the bike,it will load up the bearings and they will fail in short order.
Just a thought I had.
If you can get the rear wheel off the ground and turn it, you will know if the bearings are f*%ked immediately.
Look at No. 15 in this diagram . . . . this is the spacer I am referring to.
When you are riding, pull in the clutch to see if the vibration stays or goes. If it stays and is related to engine revs, it could need the harmonic balancer adjusted @c10 has an awesome video on this. It could be in the fuel injection, something might be unbalanced there as well.
Dopey
+1 on this. I just had this happen and it does create a vibration it'll also cause a noise in the chain when pushing the bike around if left too long. Don't ask how I know that.
WuzzaCBXRider
But he couldn’t have ridden 100 miles that way could he?
Dopey
When I rolled the wheel there was alot of chain noise but it's still doing it as if something is loose or something
If there is a lot of chain noise it can be a spacer left out, in my case it was the sprocket carrier spacer and yes everything was aligned and torqued and it actually caused the left spacer to be ground into the bearing and caused some chain noise (not as much as you'd expect) and vibration. I would lube the chain and the noise would go away when I would roll the bike around the garage but after a quick ride came back. I put a lot more miles then I care to admit with the bike like this and being a mechanic makes it even worse that I didn't chase it down sooner. It wasn't until I pulled the tire completely off that I actually found it. With the bike on the stand the noise transferring thru the chain made it hard to pin point if it was coming from the rear tire or front by the engine so you might wanna pull the tire and put your own eyes on the spacers just to be sure they are there and also not the wrong ones like @Nina just experienced multiple times on her bike. Maybe check out her "clicking" thread and see if anything in there resembles your issue.
Thread starter Similar threads Forum Replies Date
J 1 week of troublwshooting same problem help please Busa problems 20
B 07 busa reving high when turning right help please Busa problems 5
S Please help. Trying to find out the brand of swingarm to order a new jackshift for it???? General Bike Related Topics 11
B Please help in buying my very first Hayabusa General Bike Related Topics 42
R PLEASE HELP General Bike Related Topics 22
K New owner need some help please!!! General Bike Related Topics 116
mayweather88 Gen 1 Help please General Bike Related Topics 20
J Meguiars cleaning kit steps ? Please help General Bike Related Topics 7
R Brake help please Busa Mods 1
Spudley Factory decal/graphic removal, and install help please. General Bike Related Topics 15
KieranJ1992 Gen 2 Hayabusa rear wheel spindle/axel siezed. Please help! Busa problems 13
J Please HELP bike won’t start New Owners Forum 26
CadOps New Battery issues...help please General Bike Related Topics 9
Z-MAN74 Recovered from being hit by drunk driver w/ no ins. And still need front nose for 06 limited pearl white to purchase, please help I'll never throw aw General Bike Related Topics 13
S Tyre deformation. Please help. Tires 21
S Please! Need help identifying fuel tank breather hose. Busa problems 5
S Revs Very Slow Returning to Idle Help and Clarification, Please. General Bike Related Topics 3
Zekeyzeke1 Timings seems to be off please help!!! Busa problems 16
ccapse Rostra Cruise - Help Please Gen II Busa Information 7
S Error Code C12 Will Not Start… Help Please General Bike Related Topics 3
Deathtornado Unknown Header Investigation, Please Help! General Bike Related Topics 11
Mark61 After 10k Miles, Still Struggling With Low Speed Maneuvers; Please Help! New Owners Forum 72
K S2000 Injectors Help Please Turbo 21
J I Truly Need Some Help; Please (hayabusa 2002) Busa problems 17
Rileymcg32 Gen 1 Hayabusa Dyno Please Help Dyno Kings 21
Swiftfalcon Starter Gear Keep On Stripping, What Can Be The Fault??? Any Help Please Busa problems 16
elementnblind Gen 1 240 Kit Help Please General Bike Related Topics 6
S Help Me With Accessories Please? Gen II Busa Information 15
michael parris heuberger Need Help Please Appearance mods 6
F Please Help Gen II Busa Information 2
S Need Help With Cooling System Asap! Please! Maintenance and Do-It-Yourself 3
C Please Help Me Guys, Screaming Idle Busa problems 11
dandraven A Little Help Please! Missfire Issue. General Bike Related Topics 5
swerve1 A Little Help Please Hayabusa 00 General Bike Related Topics 5
Jeb 2005 Busa, F1 Code, C32, C33, C34 & C35 Fuel Injector Codes - Please Help Busa problems 12
V 2001 Hayabusa Boggs And Sputters Help!!!!!! Please And Thank You Maintenance and Do-It-Yourself 2
SSGT_B Help Please. Valve Train Noise :video Busa problems 6
D Help With Grips And Throttle Tube Please! Gen II Busa Information 5
D Please Help, With Cooling System Busa problems 0
D1busa Please Help!!! Clutch Problems General Bike Related Topics 20
CR08BUSA New Owner, Having Oil Pressure Problems! Please Help! Busa problems 5
Travis England Help With Front Forks Please General Bike Related Topics 14
J Fuel Pump Disassembly Help Please, 99-00 Maintenance and Do-It-Yourself 5
T Help Please Busa problems 3
A New Guy With A Funny Noise Please Help Busa problems 6
C Please Look And Help Me Out. Whats Doing This? Busa problems 8
A please help Busa problems 3
busa matt been a minute, back on busa, need help please Busa problems 19
P Please Help Busa problems 9
S Hello and Help please! split cases bike won't start. General Bike Related Topics 15
Similar threads
Latest Bikes
  • Bam Bam
    My Last Little Girl
    • rlmoorex
    • Updated:
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
Forum statistics
Threads
174,438
Members
48,420
Latest member
Brettmotogp
