just came back from a 7 month deployment and my busa will not go into neutral!! i had it up on the stands and my wife started it every week to keep the fluids running through it. here is what i know:
- clutch safety switch is good. (ie i pull the clutch in to start it and it starts and runs good)
- kickstand safety switch is good (ie when i kick it up with it in gear you hear the fuel injection kick in)
- i removed the clutch slave and cleaned it, reinstalled and bled the clutch still nothing
basically when i start it up and go to shift into 1st the bike dies because its not in neutral. rasied it up on the stands and started it in first. with the clutch squeezed in it stays in gear. i cant get it to go into neutral. HELP!!!!!!!
