Full*Has anyone had any problems with the bike not wanting to go over 8k rpm in 1st threw 2nd. Like wide open throttle and it will start spitting and sputtering. TC, LF is off and it has a fuel take of gas. Would bad gas make it do that?
I just put fresh none ethanol and octane booster and it still does it, it will do it all the way to 4th gearIt certainly sounds like fuel starvation but bad gas is always bad gas and would make the bike act up at any rpm.
Thank youFound this. It may not be your issue but good place to start I think
Post in thread 'Bike will not rev past 6-8k rpms at wide open throttle.'
Bike will not rev past 6-8k rpms at wide open throttle. | Gen 2 Busa Information
Is there anything in the owners manual? I don’t have my manual near me but I wonder did you mistakenly turn on the speed limiter? Not sure if the speed limiter will limit rpm’s like it does mph but I accidentally turned mine on one day and it blocked the cruise control from not working. Just a thought because I’m not sure.Has anyone had any problems with the bike not wanting to go over 8k rpm in 1st threw 2nd. Like wide open throttle and it will start spitting and sputtering. TC, LF is off and it has a fuel take of gas. Would bad gas make it do that?
I will check but it does it in 3rd and 4th as wellI remember the manual said the speed limiter will limit the speed to the mph you set it but if you twist the throttle it will still accelerate so that’s why I’m wondering if it will limit rpm in 1 & 2 but allow for higher revs in higher gears. Anyway just a thought something to check.
Gotcha I miss understand your post, let us know what you find.I will check but it does it in 3rd and 4th as well
No your good, I think it might be the injectorsGotcha I miss understand your post, let us know what you find.
On a brand new Hayabusa? I been on this site since early 2022 and no one else has had injector issues on a gen3 so I recommend doing more homework before tearing into the injectors.No your good, I think it might be the injectors
I was reading on the gen 2 page and they have a guy that had similar problems to what I'm havingOn a brand new Hayabusa? I been on this site since early 2022 and no one else has had injector issues on a gen3 so I recommend doing more homework before tearing into the injectors.
It's at the shop now. It's under warranty.Is it out of warranty?
