Power Commander 6 map problem
KoMoDo
Hello
on my motorbike
akrapovic S-S13R1-APLT Full Exhaust Systems
Racing Line (Titanium) for Hayabusa 2023
Sprint Filter P08 F1-85
BT Moto Velocity Stack Kit
Dynojet Power Commander 6
Hayabusa (2022) Power Commander V 'Street-Style' Map for Full Exhaust Systems
there are these
My problem is that when I open the throttle and reach 4500 rpm and 5500 rpm in 2nd and 3rd gear, the engine sputters as if the fuel was cut off. Then suddenly he opens the gas and moves forward. The problem is probably with the map, but I don't know what settings I should make, thank you very much in advance to those who will help me.
pcs
u can try changing the map or set the map to all zeros and see if the problem remains the same. if the issue is in the same spot regardless of the map then you know its likely not just the map. with all of your mods you likely need a dyno tune/ ecu flash.
KoMoDo
Ok thanks
I will try and let you know
Collidog
Hi there,
Looking at the mods you have it seems a likely option is to get the BT Moto handheld tuner and custom ECU flash. I have done this - I have the BT Moto stacks, Akra full system, sprint filter and PAIR valve delete. BT Moto will provide 2 maps with the handheld unit, e.g. one with exhaust, one without.
I don’t think the PCR6 you have can do justice to the nice mods you have added, but the BT Moto flash will be perfectly suited to the stacks and exhaust.
Cheers - Neil
KoMoDo
They sent me the wrong map..
I downloaded the starting map from the dynojet website and it worked.
We will make detailed mapping settings on the dyno as soon as possible.
By the way, bt-moto flash came to my mind more.
I will try that as soon as possible..
KoMoDo
Power Commander 6
Does anyone have the map set on the dyno?
can share?
Hayabusa Wannabe
For clarity, is this a blank map file with all zeroes for the fueling or is it a map designated for the Akropovic exhaust?
If it is labeled for the exhaust then it is as good as someone else's dyno map, as Dynojet has dyno'd a bike with the exhaust to produce the map.
KoMoDo
What I downloaded is an empty map
More precisely, it is a soft map adjusted for the stock exhaust.
what i need
I need a map for this system
Spudley
Grippin' and Rippin'
Talk to Chris Moore.
iron.head
Hi! I have a PC6 and a Yoshi AT2 full system. Haven't installed anything yet. Looking for a map for the PC6 with Yoshi AT2 full system and everything else all stock. Can somebody please help? Thanks..
