wreckwriter Registered Joined Dec 30, 2022 Messages 1,196 Reaction score 1,524 Feb 6, 2023 #41 DougE said: RH - 56111-15H00 LH - 56151-15H00 Click to expand... I know that but are the part numbers stamped on the bars? Trying to figure out how to tell which bar is which on a set of used bars.
DougE Registered Joined Jun 18, 2019 Messages 883 Reaction score 1,655 Feb 6, 2023 #42 wreckwriter said: I know that but are the part numbers stamped on the bars? Trying to figure out how to tell which bar is which on a set of used bars. Click to expand... That I do not know. I'd be able to take a look this evening. I have a stock set of bars i just took off the bike.
Bumblebee Registered Joined Jul 6, 2018 Messages 33,026 Reaction score 56,200 Feb 6, 2023 #43 wreckwriter said: I know that but are the part numbers stamped on the bars? Trying to figure out how to tell which bar is which on a set of used bars. Click to expand... That's the fun part... I believe they have a slight rearward angle on them...take them and hold them in place and you will see which is which by doing that. You can see the slight angle in the attached picture...that and the hole for the switch gear...
wreckwriter Registered Joined Dec 30, 2022 Messages 1,196 Reaction score 1,524 Feb 6, 2023 #44 DougE said: That I do not know. I'd be able to take a look this evening. I have a stock set of bars i just took off the bike. Click to expand... Mine should be here around noon. I'll figure it out. Looking at the two helibars I don't see any appreciable difference
sixpack577 Top Gun Donating Member Joined Jun 8, 2009 Messages 23,096 Reaction score 34,811 Feb 6, 2023 #45 It's only for the holes/dimples that locate the switch housings by their plastic pins. Hold the bars up to the switches and you'll see which is which.
wreckwriter Registered Joined Dec 30, 2022 Messages 1,196 Reaction score 1,524 Feb 6, 2023 #46 sixpack577 said: It's only for the holes/dimples that locate the switch housings by their plastic pins. Hold the bars up to the switches and you'll see which is which. Click to expand... OK thanks. I'll figure it out when they get here.
wreckwriter Registered Joined Dec 30, 2022 Messages 1,196 Reaction score 1,524 Feb 6, 2023 #47 Forgot the easiest way of all, factory grip glue on left bar. Goes stop to stop now, no contact.
