88turborx7
I haven't had any trouble installing my GiPro gear indicator up until step 9 where it says "Connect GiPro RED wire to a switched +12V wire. e.g. at the fuse box. Use the RED wire tap connector supplied." It says you can also connect straight to the battery but do disconnect if not used for 3 weeks or more. I am not interested in this option and want to use the tap connector but do not know how or where to connect it to. The wire is not long enough to reach the fuse box so i assume i have to splice into some other wire which is 12V coming from the fuse box?
