Yos_Sam
Hi, I currently have a gen 1 hayabusa in a car and am installing an electric reverse conversion. As part of the safety lock system (I don't want to activate it at 70mph) I'm trying to use the neutral light output to activate the coil on a relay that switches 12v (to power the starter reverse motor).
Issue I have is the ECU pin output to neutral switch is 5v... Is there a relay that will switch 12v using 5v on the coil?
I'm not a bread head with electrics but find my way around so be gentle..
Any advice is welcome
