turb06LE240
Does anyone have a indicator on there busa, if so what is the best one to get, my gear ratio is going to be changed 18 front 42 rear with a 240-40-18 tire
Thanks in advance
Thanks in advance
www.boostbysmith.com(turb06LE240 @ Dec. 09 2006,19:41) Does anyone have a indicator on there busa, if so what is the best one to get, my gear ratio is going to be changed 18 front 42 rear with a 240-40-18 tire
Thanks in advance
Same here - we got ours at the same time. PLug & play - 15 min install start to finish and that was taking my time. Here's a pic (that was 3500 miles ago)(hottrodd7 @ Dec. 10 2006,10:14) GI PRO here. Looks goods, works well and super easy to install
that's pretty cool..having different led's for gears.(CAT3 @ Dec. 10 2006,07:05) I'm with the everyone that pushercg talks about....I have the boostbysmith. Greg's a very good person to do business with and helpful. Besides the GI, you get a modded GPS (no more restriction) and its available with a shift light, all in a nice plug-n-play package. Even though its not a digital/numeric read-out, I have no problem with the LED's. And you can ask to have 1st gear blue, 2-5 amber and 6th in red if you want, so it would be even easier to tell 1, from 6th. GL
i would think it would replace the tre cause it does the gps mod instead so it unrestricts it the way it should be done, i am dealing with boostbysmith right now on a shift light, and after reading some of the other things he does i wish i would have went with the leds for gear indicators and shift lights and launch lights. seems like a good setup(runeight @ Dec. 10 2006,08:56)that's pretty cool..having different led's for gears.(CAT3 @ Dec. 10 2006,07:05) I'm with the everyone that pushercg talks about....I have the boostbysmith. Greg's a very good person to do business with and helpful. Besides the GI, you get a modded GPS (no more restriction) and its available with a shift light, all in a nice plug-n-play package. Even though its not a digital/numeric read-out, I have no problem with the LED's. And you can ask to have 1st gear blue, 2-5 amber and 6th in red if you want, so it would be even easier to tell 1, from 6th. GL
Wonder if this will work with the Ivan simple TRE of does it replace the TRE?
runeight...
Which pics are you talking about?(dadofthree @ Dec. 10 2006,17:55) So, the pics of the segmented LED. Is this the gear indicator ? If so I assume it gives you a numeric display
