Hi guys,
I know it's a couple of years ago now since this post was last commented on, but after lots of searching on here it's the nearest I could find to my problem with my fuel gauge. I'm considering using "sending unit 2" (I have two) and re-sitting the needle 50% lower than it currently is. But before doing anything dramatic, I wondered if you could spend 5 minutes reading below and offering any advice please? All the below was done on an empty tank...
Sending unit 1:
Connected to loom --> Switch ignition on --> Gauge goes to half full --> Gauge drops to empty --> Dials go to full --> Dials drop to 0 --> Gauge goes to the full position
This happened when the unit was inside the empty tank, regardless of which way the unit was sitting.
When the unit was disconnected from the loom, this is what happened...
Switch ignition on --> Gauge goes to half full --> Gauge drops to empty --> Dials go to full --> Dials drop to 0 --> Gauge stays at empty and reserve light comes on.
When the gauge is reconnected with the ignition on, there is no change. I believe this unit is faulty.
Sending unit 2:
Switch ignition on --> Gauge goes to half full --> Dials go to full--> Gauge drops to empty --> Dials drop to 0 --> Gauge goes to half full and reserve light
comes on.
This was done whilst the unit was out of the tank. Is it possible to test this way, or does there have to be some pressure against the unit for it to work properly?
I then held the unit's float upright...
Switch ignition on --> Gauge goes to off the clock (i.e. 50% higher than full --> Release the float --> Gauge drops to 50% and light comes on after 3 minutes
For this reason, I think the unit is working, but reading 50% higher than actual value. Feel free to laugh at that...!
So, any help or advice would really be appreciated, (common wiring or unit faults, blown fuses etc.). Surely I can't be the only one this has happened to...?
Many thanks in advance.
