Fi light when i use my air shifter?
PORT
I installed my air shifter and finally got around to trying it. The air shifter worked great except I noticed code F1 was flashing after I used it a few times (I was not spraying at the time).  I stopped for lunch and when I started the bike up, everything was normal.
Any input?
            Thanks
Have heard that is you cut the black wire on SOME kill boxes this condition disappears. Not on all. This came from the guy at MPS I talked to a few months ago. You may want to research the color wire to cut before you go snipping away but I'm pretty sure that's correct. It's annoying but if it really bothers you and the black wire trick doesn't work, there's always the electrical tape over the light trick
yeah they told me the same thing....only mine wouldnt adjust enough to kill quicker. i sent it to them and they modified it so it has more kill adjustment and the light doesnt come on.
