factory pro shift kit
cole414
i installed the s92 factory pro evo shift star and spring on my 08 orange and black because i kept getting a false neutral between 5th and 6th gear, before this i adjusted the shift lever down some to get more leverage on the shifter and put amsoil 10-40 oil in, this didnt help any, so i buttoned everthing up, take off for a test ride now i get false neutral between 3,4,5 and 6th, its unrideable, so i will take it back apart to see if i done something wrong, it has 1300 miles and never abused, when i realized it was worse now than before i installed the kit, it felt like somebody kicked me in the stomach, any help would be appreciated.
mcbusaturbo
where it ends up between the gears and not actually in either say 3rd or 5th but the detent arm does not go into the resesed area for the gear it gets kind stuck somewhere in between so you thought you shifted and get on the throttle only to find a lott of revs and now power through the transmition
jefro
Take it back apart-something's wrong.
I did mine this past spring and love it! Much less effort and more positive shifting. Install is a little tricky but not that bad.
My '08 also has what I call a double shift that is sometimes felt shifting into 6th and once in a great while going into 5th, also. It feels like it hesitates in between gears but as long as you keep pressure on the shifter it completes the shift unless I'm really shifting lazy. It only occurs at lower rpm and really isn't much of a issue IMO, at least on my bike. After installing the shift kit the notchy 5-6 is still there but the effort to get past it is considerably less.
I suspect you may have an issue with the new spring-double check the install of the detent lever and spring. The detent roller should line up correctly with the star. The star can only go on one way so that should be fine. Check it out and let us know.
cole414
for those wondering what i did wrong, when i tightened the arm with the spring and little bearing on the end, the spring wasnt seated just right where the bolt passes through it, and it was binding not allowing the arm with the little bearing move up and down freely, now its all good, no more missed shifts so far, was well worth the money.
Thread starter Similar threads Forum Replies Date
B Factory Pro Shift STAR Kits... worth getting ??? Busa Mods 12
AJAY Factory Pro Shift Kit - any updates? General Bike Related Topics 10
G Factory Pro Evo Shift Star Kit Installed Gen II Busa Information 6
C Factory Pro Tuning EVO SHIFT KIT General Bike Related Topics 9
K Wolf Factory Pro shift star Engine and Performance mods 8
O Factory Pro Hayabusa SHIFT KIT Modifications & Aftermarket Equipment 2
squale147 Factory Pro Superflare RACE V Stacks Gen II Busa Information 21
B-12 Factory Pro dealer in New York General Bike Related Topics 3
Titaani Factory Pro Ignition Advance Kits Engine and Performance mods 7
dmrowe Factory Pro Dyno Results Dyno Kings 30
O Group Purchase(GP):ShiftKit from Factory Pro. General Discussion 9
O plugs & factory pro Modifications & Aftermarket Equipment 7
202mphbusa Gen 1 Factory Baro sensor voltage General Bike Related Topics 6
Spudley Factory decal/graphic removal, and install help please. General Bike Related Topics 15
04 Limited Busa Factory suspension settings Gen II Busa Information 6
GAmedic Who else likes the factory body? Appearance mods 58
J Factory exhaust New Owners Forum 4
Jose J Ortega Valves acceptable Factory Spec Maintenance and Do-It-Yourself 18
S 1st Gen Factory Riding Height General Bike Related Topics 1
zook Blue Marks On Factory Clutch Drive Plate Claws Gen II Busa Information 2
Captain Scallawag Cleaning Factory Decals? General Bike Related Topics 20
Cjbowler Can The Factory Stator And Rectifier Handle????? Busa Mods 9
rubbersidedown M Factory Buell Lowering Pegs Free To Good Home. General Bike Related Topics 2
1 Replacing factory 2009 Busa decals / color scheme - suggestions please? General Bike Related Topics 12
piratediverjefff Setting Factory Shift Light Gen II Busa Information 8
V 2001 factory fairings New Owners Forum 3
E Zurcher Factory fairings General Bike Related Topics 4
groran1000 What do i have to change to use 2 inch lower pegs w/ factory exhaust gen2 General Bike Related Topics 4
DaBuzaBoy M factory Electrical Mods 1
FireMedic What size spring is on a 2007 Factory Busa Busa Mods 3
M WTB: 2013 Factory Decal for White Hayabusa Gen II Busa Information 10
C How easy to restore to factory stock? Gen II Busa Information 7
04LE 2014 Bimota DB11vlx Factory Supercharged! Super Chargers 5
Flicka Texas Fertilizer Factory Random Thoughts 18
B Stripped the head of a bolt taking off the factory exhaust Busa problems 20
H Factory style paint masks Appearance mods 2
2 factory rearset bushings (pita or pinta bushings) General Bike Related Topics 12
F Extensions issue, swingarm tweaked form factory? Busa problems 9
M Hayabusa factory service manual 1999-2007 General Bike Related Topics 0
card16969 powdercoating factory rearsets General Bike Related Topics 41
bigjack7679 Opinions on modifying factory seat General Bike Related Topics 21
R Where's a good place to get Factory Decals? New Owners Forum 8
ogre 2013 BUSA, Confirmed factory turbo!!! Random Thoughts 35
Tiller Can you run a 180/55 tire on a bike that runs a 190/50 factory? General Bike Related Topics 15
cajmex11 modifying factory exhaust on Gen II Busa Mods 1
InfiniteReality How To Tighten Up Factory Mirrors? Gen II Busa Information 0
P Time to dump the factory cans Engine and Performance mods 3
B Removed Factory Chain and would like to clean it Maintenance and Do-It-Yourself 8
B K Factory Diablo-S Full exhaust Busa Mods 0
K Factory Horn Harness Location Electrical Mods 8
Similar threads
Latest Bikes
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
Forum statistics
Threads
174,430
Members
48,416
Latest member
bert2588
