jkwool
- Joined
- Apr 21, 2010
- Messages
- 38
- Reaction score
- 1
Hi,
Quick intro first: I have not really posted on here much but i have been around reading posts etc for some time. I have been working with Petri on ECU Editor for awhile now.
I have been working on some functionality for ECU Editor over the last week or so to allow people with a Boost by Smith ECU Harness and the stock oxygen sensor (in your exhaust pipe) to log and analyse engine data to your laptop for your Gen 2 Busa and Bkings
The idea for this is to allow guys who dont have access to a dyno tuner or a wide band oxygen sensor to be able to get an idea of how their bike is tuned by plugging in a laptop and going for a ride while logging data. I also plan to provide functionality which will suggest changes to the fuel maps to improve the tune of your bike based on the logged data.
The logs contain the following information:
RPM
TPS (Throttle Position %)
IAP (Inlet Air Pressure)
HO2 (ECU AFR reading)
IGN (Ignition Advance)
STP (Secondary Throttle Position)
GEAR (Selected gear)
CLUTCH (Clutch in or out)
NT (Neutral indicator)
CLT (Coolant Temperature 'C)
IAT (Inlet Air Temperature 'C)
BATT (Battery Voltage)
The first stage of this development is to get the logging functionality working and an accurate Air Fuel Ratio (AFR) conversion function. I have the logging working and I am now working to improve the AFR calculation.
This is where I could use some help
Would any of you guys out there with Wideband Oxygen sensors on your bikes and logging ability be able to do some side by side logging with both your wideband and the ECU Data Logger. If you send me both sets of log files from the same ride I will be able to compare the results and improve my AFR calculation for the built in oxy sensor.
I have already improved the AFR calculation thanks to Greg for sending through some logs from his bike, but as with all things like this the more data the better results i can get!
When i have the above working reliably i will look to incorporate this directly into ECU Editor.
A test version of the logging application is available for free download here: ECUDataLogger.zip - Windows Live
Instruction for using the ECU Data Logger
ECUDataLogger @ gmail.com
Thanks
-Justin.
RPM
Would any of you guys out there with Wideband Oxygen sensors on your bikes and logging ability be able to do some side by side logging with both your wideband and the ECU Data Logger. If you send me both sets of log files from the same ride I will be able to compare the results and improve my AFR calculation for the built in oxy sensor.I have already improved the AFR calculation thanks to Greg for sending through some logs from his bike, but as with all things like this the more data the better results i can get!
- Download the .zip file from the above link
- unzip the ECUDataLogger folder onto your laptop
- Plug your ecu interface into your bike and laptop
- Click on the ECUDataLogger.exe application
- Select the COM port for your ECU Harness
- Start your bike (after a short delay you should see some basic info appear on the screen TPS, RPM, IAP)
- Click "Create Log File" to create a new log file, save it where you can find it on your laptop hard drive
- When you are ready to start logging click the "Start Logging" button
- When you are finished logging click the "Stop Logging" button
Thanks
-Justin.
to get the accuracy
lease: needed to adjust to and with using a narrow band input ?
) just bumming along learning as I go.
