Rod hammered, rod bearing?
bearing got hammered because piston met valve...
I'm not sure I understand yer last post Bug.
Sure...replace everything...why not...
If it were me, I would want to know the cause.
What if the cam chain had somthing to do with it,and it doesn't get replaced.
Friendly advice.... if yer not a drag racer....
Why bother.
Find a good motor outa some squid fugwads downed Busa.
Buy it,bolt it in. happy days are here again.
Do you have any idea how much the balacing/blue printing,head,valves,springs,gaskets,cams,chains,rods,pistons,head work,machining,beefed up battery,starter gears,......blah blah blah... its endless...you'll be months gettin' back in the saddle...
just be preparred for a shid-load of expenses...
and the fact that yer now sittin' on a motor that could NUKE easier than the one you had before.
friendly warning.... Rubbah.
