GXR1147
i was hoping to order up a water/meth kit this week but yesterday this happened. On a 3-4 upshift at like 45 mph all hell broke loose and cringe worthy noises happened. I'm thinking the stud backed out and got wedged between the outer hub and cover. As I went to take stuff apart, none of the spring bolts were tight. 2 years ago when I assembled it all I used lock-tite on them before torquing them. Oh well, guess that didn't work. Got lucky as it could have been a lot worse. Looks like just the outer hub, springs, bolts, studs and cover were the only parts damaged. Gonna drop the oil pan, check the pick up, pull the oil pump check in there and the side galley plug and make sure all that stuff is clean/gets cleaned out.
So now I'm looking at what parts to upgrade and what parts should be OEM etc. I saw a 1 piece inner hub but then read that the factory 2 piece provides more clamping force (w/ heavier springs like I had) and the 1 piece can slip under "low/normal" power levels on a turbo bike. This is a stage 1 RCC kit making 235whp @ 7.5lbs. I need to know what my options are. This is solely a street bike and will never see a track if any kind.
