Hey guys, i have a serious problem and I'm not sure what's wrong. I changed my clutch out. I had squeezed the lever a few times with the clutch out and it pushed the pin out as im sure it should. When I was trying to torque the pressure plate back, my wrench wasn't working properly and I ended up snapping a bolt.. no biggie. I took off the hub nut and removed everything. I extracted the broken screw successfully. I put everything back in exactly how it came out. Got the pressure plate on and tightened them down snug but not too tight... the pressure plate was a little bit away from the clutch disk. i squeezed the clutch lever and it allowed me to squeeze but the clutch plates weren't seperating...i squeezed it again and something popped and the pressure plate was now tight against the basket. But when i went to squeeze the clutch it is completely stiff. I cannot squeeze it at all. I took the hub nut back off and removed everything again down the where the picure i posted below is... i still cannot squeeze the clutch lever. Its Jammed and stuck on something. If anyone has any idea of what it could be please let me know asap!
