apbrian112
hey guys (and gals), my busa's having a problem holding a charge.
i just put in a new battery last week and it wouldn't hold a charge overnight.
i put a battery tender on it til it was fully charged then performed some tests according to the service manual. here are the numbers:
1. Battery current leak inspection. manual says anything under 3mA is good.
my reading: .75/.90 mA it changes from .75 to .90 then back again (continually with about a second inbetween)
2. Charging output inspection. manual says anything between 13.4-15.1 V
my reading: 14.5 V at 5000 RPM.
now according to those two readings (w/i spec), the manual says that it's either: bad battery or abnormal driving conditions (but since i'm not driving/riding it, and it's dying over the period of 1 night i'm counting out "abnormal driving conditions").
specs on bike:
-2001 hayabusa
-30,000 mi
mods: pcIII, K@N filter, modded mid-pipes, tre, lowered front and rear.
thanks for any help you guys/gals can offer thanks.
oh, almost forgot. while i was doing the tests, i was checking the wires coming out of the stator and it when i unplugged it, there was a oily substance in and around the plug (i'm guessing this is dielectric grease). is this normal?
specs on bike:
-2001 hayabusa
-30,000 mi
