birdaprey
- Joined
- Feb 2, 2003
- Messages
- 1,253
- Reaction score
- 6
what do you all think happened?
I had the rear wheel off waiting on my new tire to come in, so I checked my rear brake pads while I was at it. they needed changed so I pushed on the old pads to get the pistons back in... then I changed out the old pads and put the new ones on, pumped the brakes a few times and called it quits for the day. after I got the tire back on I went for a test ride; later that day I saw brake fluid leaking down from the top of the master cylinder line that connects to the part behind the heal gard/foot peg?
could I have pushed fluid back in to the master cylinder some how and caused it to leak out the end of the hose where the pinch clamp is??
thanks guys...
<!--EDIT|birdaprey
Reason for Edit: None given...|1086747245 -->
thanks guys...
<!--EDIT|birdaprey
