Sky Rider
Hey guys.
I'm currently in the middle of rebuilding my engine and ran into an issue. While installing the cams everything goes well until the tensioner is installed. Once tension is applied the crank turns about 20 degrees CCW. I'm using cams with Ape adjustable sprockets. I've tried re installing several times and always get the same result.
