I'm 6'8" tall with a 38" inseam. More leg room is something I can definately use. I just got my Buell pegs, ground them down and mounted them. I didn't have much time, so I just went for a 50 mile ride to check them out.
Benefits:
1. They remove the strain from the knees.
2. My knees fit better into the pockets on the tank.
3. It was easier to tuck behind my windscreen because
my elbows didn't hit my knees as soon as with the stock
pegs.
Down falls:
1. They put more strain on my ankles and lower back.
2. The foot controlls can not be adjusted to where they
need to be. For the brake pedal the end of the
adjustment bold needs to be cut off to allow the pedal
to adjust further down. The shift lever can not be
adjusted far enough down. I adjusted it until it
just hit the kick stand when it was depressed and it still
wasn't far enough.
3. The pegs space your foot further out from the
mounting pin than the stock pegs do. Because of this
and the kick stand being so close to the shift lever now,
I had to go pigeon toed to catch the shift lever with just
the edge of my big toe to shift. It also felt a little strange
having my feet futher out from the bike. I would probably
get used to that over time though.
4. Because of the lower foot position the swing arm kept
hitting my heels on the rougher bumps.
5. The Buell pegs aren't as wide as the stock pegs, so
the outside of my boot hung over the edge more and
made it feel not as stabil as with the stock pegs.
If I was going to go an a very long road trip I would put the Buell pegs back on my bike. For local riding though, I am going to stick with the stock pegs. I did modify my stock pegs. Originally they put strain on my ankles because they rose up on the outside of the peg. I took my dremel, with a sanding drum on it, and ground the outer piece of rubber, that came up higher than the other ribs, down so that it was level with the other ribs. It was so easy to do that I decided to grind all of the ribs completely down. It gave me a completely smooth, flat rubber piece on my pegs and about 1/4", maybe 1/2", more leg room. Which is nice.
Benefits:
pegs.
Down falls:
wasn't far enough.
