lzeplin
I recently bought a 04 busa, up front it only has 1 disk and caliper. It stops it fine but this bike is real easy to get into trouble with and Id rather have the double setup. The wheel looks like a factory wheel that's just been chromed, on the right side is a block off plate but it doesn't have bolts holding it on. You can see the seam where the plate joins the wheel, the plate also say's hayabusa . But my question is how do you get it off? Could it be some kind of sticky tape?
Also there's only one red brake line running from the master cylinder to the caliper? What do I need to split it 2 ways for the new caliper and rotor? Thanks for all the help, I'm brand new to busa's. I have a zx9r that I've had for years but just routine maintenance is all I've ever did, Anyway thanks for all the help!
