Bluegauges problem?
Youkai
I have noticed that my bluegauges background lights will flicker while I am idle in gear/neutral. When any amount of throttle is applied, the light stays constant. Is this normal? I can understand the generator output is lower when at idle, but still I don't think it should matter.
The race:
Had a 69 Camaro Z28, black with white stripes race me today. It had drags out back, skinnies up front, a cowl hood, and I believe I smelled race gas. Started on a 20-30 roll, had 2 1/2 cars on him by mid 2nd gear. I gave him a thumbs up on the car before we raced. Ah I love some things about Detroit.
thepushercg
veni vidi vici
sounds like a loose ground. i dont think that is normal.
SnapAttack
What is idle? 1150 or better?
Mine don't flicker. They do however make a frequency humm if on the high setting. I keep them on low and all is well.
Youkai
My idle is set at 1500 rpms, I will recheck the wiring to make sure nothing is loose. I believe I have them set on low as well.
dadofthree
Seasoned Beef
Call bluegauges
Justyntym
The Pessimistic Optimist
Mine don't flicker at all...something is amiss.
werdkat
Mine are starting to flicker also...sometimes I don't even have gauge lights. However, I have ruled it down to the switch where you adjust hte brightness, after playing around with it. I contacted Scott at blue gauges and asked if they sold one he said they sell the switch and fuse block for 20.
BusaWhipped
(dadofthree @ Jul. 11 2007,22:36) Call bluegauges
+1. Scott stands behind his work. If there is something wrong, he'll make it right.
